All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Nafeun on July 11, 2013, 03:25:49 pm
Hello,
I updated the firmware on my new D 510 RNS to the newest modified one which deleted map data.
I then put in the 7920 map DVD and started to install it however I needed the car so stopped it. It now works absolutely fine however I doubt the full disc was installed. Also the speed camera POI are not on the drive. I have attempted to install the maps again however when I inset the map DVD nothing happens. Any idea?
Have you selected the pois through the setup menu?
Sent From My Samsung S3
It's not there :(
Hello,
where can I get a copy.
Thanks :happy2:
ok, which fw are you on now?
4120 modified for Europe. The poi setting in settings is greyed out. Do I have to manually add then through an sd card even though they have been added to the map data ISO?
As per link, I got it from rnsfirmware.com and maps I can't discuss...
Try 3800/3810 modified, I had the same problem when I went to 4120.
Cheers will do, any links for either firmware? Can't find it on rnsfirmware.com?
