All Things Mk5 => Mk5 General Area => Topic started by: Craigh1983 on July 13, 2013, 07:33:52 pm
Title: Possible PCV failing?
Post by: Craigh1983 on July 13, 2013, 07:33:52 pm
Hi guys,
Have a stage 1 remap and recently had a new turbo and dv valve change. Car pulled like a train. Recently I have noticed it doesn't seem to pull as much when I put my foot down.
So I thought I'd try taking out the oil dip stick to see if the car would hunt. When first taking it out the engine grunted slightly and then very slightly started to rev a little faster but it didn't really start to chug a lot like I remember it doing before.
Could this be a sign that the pcv has had it?
Craigh
Title: Re: Possible PCV failing?
Post by: Saintsteve on July 13, 2013, 08:39:03 pm
Remove your engine cover and try a blow back test to see if the valve leaks?. I would check that before parting with your 35 hard earned.
Post by: Craigh1983 on July 13, 2013, 08:47:44 pm
Hi Steve,
Err sorry how do I do a blue back test? :)
Post by: Saintsteve on July 13, 2013, 09:04:21 pm
Quote from: Craigh1983 link=topic=69469.msg752607#msg752607date=1373744864
Hi Steve,
Take the main plastic hose off, and try blow/sucking  :signLOL:
 :wink:
Post by: Craigh1983 on July 13, 2013, 09:09:47 pm
Errrrrr ok.... Lol
What will I be looking for when I'm blowing and sucking? Lol
Post by: Saintsteve on July 13, 2013, 09:13:20 pm
You will feel a ball valve feeling which only should allow air flow In one direction.If you don't, then it's duff  :smiley:
Post by: Craigh1983 on July 13, 2013, 09:15:11 pm
Ahhh I will give that a try tomorrow :)
Cheers Steve!
Post by: Craigh1983 on July 13, 2013, 09:25:24 pm
One more thing. Do I do that with the engine running or turned off?
Post by: Saintsteve on July 13, 2013, 09:36:57 pm
Turned off...   Could be interesting if you did with it on though..
You might get a whiff of oil vapour when you check it ok, so have the mouthwash to hand  :laugh:
