All Things Mk5 => Mk5 General Area => Topic started by: E30Dom on July 18, 2013, 02:38:56 pm
Title: Tell me about your squeaks...
Post by: E30Dom on July 18, 2013, 02:38:56 pm
Ok I have a demonstrable squeak coming from my engine bay... basically on a slight decline if i try and reverse up the slope with handbrake slightly on to create more resistance and bring the clutch in slowly on low revs letting the revs die more I get an annoying squeak...
Anyone had similar and what was it... booked in next friday to have it investigated further as the garage weren't able to hear it, till i got there to collect and demonstrate it...
Anyone...
Title: Re: Tell me about your squeaks...
Post by: Nodz on July 18, 2013, 04:02:25 pm
Mine makes a squeek if I pull off with low revs with the air con on, if the air con is off its fine
Post by: CAPTAIN BRITAIN on July 18, 2013, 04:17:08 pm
I have this squeal at low revs also, haven't tried to pull away with air con off though.  I'd like to know what's causing it.
Post by: doylebros on July 18, 2013, 08:29:17 pm
Possibly corrosion on the brake disc or discs (inboard side) could cause than - or a sticky pad!
Post by: E30Dom on July 19, 2013, 08:35:01 am
Mine happens when cars stationary...
Post by: Gene Hunt on July 19, 2013, 12:29:54 pm
My ED30 started about 6 days ago with a really annoying rattle/vibration which sounds like it's some where in the cabin/dash area?. Tried everything I can think off but no joy. Only does it on tick over, soon as you set off it stops  & when engine is running & you get out the car it cant be heard so def on the inside .  Doing my head in now!!!!!!. :rolleye:
Post by: Andy on July 19, 2013, 12:54:47 pm
used to have a squeak near the glove box--but sorted it now
