All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: nelmser on July 18, 2013, 08:26:37 pm
Just bought these from eBay:
http://www.ebay.co.uk/itm/271225756624?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 (http://www.ebay.co.uk/itm/271225756624?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649)
Turns out I bought the wrong size so I'll have to reorder....
Are these easy to fit? I don't really want to remove the wheels... They look like they can just clip in?
It's a lot easier it you remove the wheels as they just push out from behind. You can use a flathead or similar to tease them out but you run the risk of damage.
If the old ones are finished (whiteworm) just drill a small hole in them - this allows you to pull them off (your prefered method - small screw and Pliers for me) without removing the wheels - new ones then just press in by hand!
Job done in minutes, if not and you want to keep the old ones - wheels off and knock out from the rear of the wheel.
As above, if they have whiteworm then drill a wee hole (carefully) and Roberts your mothers brother. If you want to keep them. Then use a plastic trim tool.
What size are the standard centre caps for 18 inch monzas?
Best measure the ones fitted - 65mm outside diameter rings a bell though!
Size is 65mm outside and 55mm inside IIRC. If you need it, the OEM part number is 3B7601171XRW and they cost about £7.50 each.
Took mine off earlier today part number on the inside is 3B7 601 171 plenty available on ebay. Replica ones are £7 a set
Easiest way is to tap a hole with a small screwdriver then prise them out.....simples.
Blowtorch: melt the barstewardss :wink:
