All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Jussa on July 22, 2013, 01:05:17 pm
It's about 33 degrees today in London, and my temperature gauge says 21.5 and took around an hour to move to 22 :scared:
It hasn't moved from 22 - does anybody have any suggestions???
Knackered thermometer maybe?
Where are these located and are they expensive and/or easy to swap?? :confused:
it is in or behind the lower grill
Do you reckon it's the thermometer, or is it a sensor?
Is it easy to swap?
Most likely the sensor
Thanks guys - is it expensive and an easy swap?
Also, will it affect how the car gives me hot or cold air by way of the climate control? :confused:
Disconnected the battery, then reconnected afte a few minutes, it then showed the correct temperature of 36 degrees. Problem now though is its still saying 36 degrees and its clearly a lot cooler :confused:
