All Things Mk5 => Mk5 General Area => Topic started by: Nayo on July 25, 2013, 08:32:07 pm
Which do u prefer are recommend and why?
Videos welcome
Best performing, sounding, value, quality
TFSI is designed to have the boost recirculated to minimise turbo lag. The noise is for Scoobys etc :grin:
People have run "dump valves" but found the engine doesn't run very well. You can get a DV spacer from Forge which gives the noise but has been proven to lose power.
Your best off with the OEM REV "G" DV :happy2:
I ran the forge adjustable Atmospheric valve on my last vRS for a while (around 20k miles) and never had any issue with it. It held boost fine on mine. I only got rid when i relocated the DV.
Ok thanks for that so would u say to just leave it standard and maybe just upgrade the intake?
Yes! The right intake would make some fantastic noises. Try Evoms :happy2:
run a vacuum to the TB pipe from a solenoid if your going to run full atmos and you will have no probs if its noise your after
