All Things Mk5 => Performance Modifications => Modifications & Technical Area => Revo Zone => Topic started by: kahunajb on July 27, 2013, 08:53:16 am
Title: Revo Stage 1+
Post by: kahunajb on July 27, 2013, 08:53:16 am
I will shortly have the following mods:
CAI
Autotech hpfp
Pre cat delete
Revo Stage 1
Is it possible to tweak the settings on Stage 1 Revo to make full use of the above mods or is a custom map such as R-Tech required?
Title: Re: Revo Stage 1+
Post by: bacillus on July 27, 2013, 09:54:53 am
Seeing you have an uprated hpfp then you could up the standard boost and increasing fuelling with a sps switch without running into fuel cut problems.
Post by: kahunajb on July 28, 2013, 05:58:09 pm
Does anyone know if there would be a noticeable difference getting a custom remap over tweaking the Revo settings?
Post by: berg on July 28, 2013, 08:20:16 pm
CAI
Autotech hpfp
Pre cat delete
Revo Stage 1
you only need the downpipe and you are at stage 2.
you can always go 2+ later on with intercooler and full tbe
Post by: kahunajb on July 28, 2013, 09:37:34 pm
Yeah I know but can't afford the brake and clutch upgrade.
