All Things Mk5 => How to Guides / Troubleshooting => Topic started by: mk4gti-t on July 27, 2013, 02:39:02 pm
Just drove home from work no problem, half an hour later car wont start! When ignition is on both fans kick in and run continuously and the temp gauge is showing nothing at all. Car turns over but will not fire. VCDS cant connect to the engine controller and also dsg lights are flashing eg all of them pnrd etc....HELP!
VCDS log.......
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ5W241797 Mileage: 132910km/82586miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: None
VCID: 55AB9F8DBC1A771
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 042 M HW: 02E 927 770 AD
Component: GSG DSG 041 0824
Revision: 00004010 Serial number: 00000504110582
Coding: 0000020
Shop #: WSC 01279 785 00200
VCID: 1D3BC7ADC4AAEF1
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0004738
VCID: 3A712C317544B89
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6CDDDA694F90D69
1 Fault Found:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001696939
Coding: E58D8F2600041819001400001400000000087F075C
Shop #: WSC 12345 123 12345
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00480286
Shop #: WSC 12345
2 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 08 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0C0THA
Coding: 0012344
VCID: 377735054656A51
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0010042
VCID: 356B3F0D5C5A571
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 960 D
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0001403
Shop #: WSC 01179 210 93569
VCID: 30650E19A338729
1 Fault Found:
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001054110B34
Coding: 3F0F0340070001
VCID: 2953E37D80E2031
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 132915 km
Time Indication: 0
Date: 2000.00.00
Time: 13:42:48
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0812
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0122
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 31630B1DA8327B1
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Mileage: 2880 km
Temperature: 38.0°C
Voltage: 12.40 V
Voltage: 12.30 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 19D802487F2D8505481AC69010CC
Shop #: WSC 01392 785 00200
VCID: 78F5F6390BC86A9
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 014 0022
Coding: 0040402
Shop #: WSC 00000 785 00200
VCID: 2F670D65BE066D1
End ---------------------------------------------------------------------
Sunday morning bump :-) Anybody had issues like this before? Could it be can bus related or hopefully a loose connection on the ecu?
sounds like a wiring issue on the drivetrain CAN wiring
Thanks for the reply eddie. A couple of questions A - where do i start lookking and B - would this stop vag com reading the ecu? Cheers.
All the no signal/ no communication errors to me means no power going somewhere.
disconnect battery an reconnect? Prob wont fix it but might reboot something.
Its weird how the car can be fine, drive ok then after turning it back on not start!
You don't have a after market immobilizer or like the APR maps a "lock out" feature on your map?
No car is totally standard. It is wierd as there was no warning at all, no lights on the dash on the way home from work whatsoever. The only thing i did was jet wash it on the way to work but it started fine on my way home...Strange :surprised:
Ive just disconnected the battery and tried it again but still the same only now the steering wheel light is staying on amber???
That's normal after battery disconnect.
Oh thanks. Ringing the dealer i got it from first thing tomorow, hopefully they will be able to help :scared:
Seen this before where the radio wiring /dash wiring was pulling down the Can have you been doing or had any work done lately?
If not you'll have to disconnect each module on the gateway to trace the area where the short is consuming all the power!
Great thanks for the advice. How do I go about disconnecting each device from the can? Ta. Oh and no work has been done at all. The only thing I did previously was to jet wash it the morning before it failed. I did wash under the arches quite thoroughly so water may have got in somewhere.
Start with the most common failure items ecu,instrument cluster etc and re-scan then check to see if the other items communicate with each other.
If its the ecu - then check the exhaust sensor wiring hasn't burnt through / was a common area if exhaust mods have been under taken.
Ok but how and where should I disconnect them from? Also the car is totally standard as far as I know so no exhaust mods have been done.
Most of the items just need unplugged i- f you can reach them however,not everyone is simple to get to!
The cluster is easy start there -
http://forums.vwvortex.com/showthread.php?3604801-DIY-hi-line-cluster&p=44436968&viewfull=1#post44436968
Just go to the section which shows the cluster being removed on the link and as I say rescan and see what shows up each time.
Ok thanks once again for your help.
Having no joy at all with this! Need to get it to the dealers but as ive got no breakdown cover im screwed. Anyone got a car transporter they want to lend me lol
Battery fully juiced? You've probably checked that already and I know it seems obvious, but when I did my ABS purge a while back, it depleted the battery just enough to give loads of warnings on the dash, car wouldn't turn, error codes via VCDS... quick charge and all was right with the world.
More than likely not this, but always worth trying the simple things. Best of luck with it mate :happy2:
Yea battery seems fine although the green indicator lamp on the battery isnt illuminated. The car turns over fine just wont fire up :mad:
This makes 2 of us. Its happened to me, I jetted my car and it died when i got home. Its the ECU, you must of got water in.
When you turn your key, do you get the engine light on (I didnt). Try borrowing another ECU and plug in and turn the key (you should get the engine light but wont start cos of the immo), this way you can make sure before sourcing a ECU.
No i got the traction control and tyre pressure warning light. Also the lights for dsg were all flashing. I had no readings on the temp gauge and my fans are running very fast.
All the lights come on apart from the engine light (not sure if thats the correct name), the orange/yellow one on the left if the dial. Because if the ECU is dead it can't communicate with it therefore no indication.
When i try and scan with vag com it keeps trying to connect but drops out almost as soon as it manages to tries to talk to the ecu???
Hi guys I was wondering if anyone actually found a cure for this? I’ve got exactly the same issue that started a little while ago but haven’t had a chance to look at it till now. I’ve checked the fuse box for water. Replaced the relay on the ops under the steering wheel. I’m running into a bit of a dead end and wondered if anyone had any more info on this thread?
