All Things Mk5 => Mk5 General Area => Topic started by: Rumple on July 30, 2013, 10:05:47 am
Title: Is this normal?
Post by: Rumple on July 30, 2013, 10:05:47 am
Fitted my new forge twintake last night, and took it out for a test run. Performance wise everything felt good and a slight improvement but I cant get my head round the noise it makes? Although it makes the noise I expected at points there's a rather strange whistle cant work out if something's wrong or its normal any ideas?
Another short clip where the whistle is more poignant, really strange noise like being a game show! haha
Title: Re: Is this normal?
Post by: Scottymon on July 30, 2013, 10:08:20 am
Unfortunately, that's just a K03 thing with an aftermarket CAI, some have it some don't.  Not just the Twintake that gets this.
Post by: Rumple on July 30, 2013, 10:19:52 am
Thanks for your reply, is there no way to dampen the whistle or cut it out?
Post by: john87 on July 30, 2013, 12:03:12 pm
When I had mine fitted to my GTI, I could only hear a slight whistle upon heavy acceleration. Could be a recirc valve-related issue? Also, make sure all your jubilee clips are 'done up' nice and tight.
Post by: GTI-Pirelli on July 30, 2013, 02:51:47 pm
Put the standard intake back on.  :happy2:
Seriously though, the reason that the aftermarket intake is so noisy is because it is designed purely for performance. The standard air box/filter is restrictive as it is a compromise. Most people don't like their cars to make weird noises so VW designed the intake to be quiet and of course cheap to make. The routing helps to baffle the noise but also restricts airflow.
The CAI has a big hollow pipe with effectively an open end, air passes through easily and so does sound! Think of it as a didgeridoo!
Most of the time I quite like my P-flow but there are the odd occasions I wish it wasn't so noisy. It's staying because of the performance benefits.
Post by: rich83 on July 30, 2013, 02:56:48 pm
That noise it rediculous..... :signLOL:
Like like someone blowing on a bottle.
Does the twin take have the K04 tap on it?
Post by: Rumple on July 30, 2013, 03:01:41 pm
Haha that's one solution! Just not sure if I've done something wrong its not so much the loudness or the sound of the air its that bottle blowing noise that richwig is kindly mocking  :sad1: going to go over all the clips tonight and see if I cant stop it somehow! have been looking at videos all day and none have sounded quite like mine so im hoping there's something to be done! thanks for all responses though guys really need some input!
Cheers, Ash.
Post by: Vasekk on July 30, 2013, 03:15:14 pm
I am getting this with P-Flo too sometimes.
Post by: edd666999 on July 30, 2013, 04:36:55 pm
Mine sounded like that.
Stop spending cash on a CAI and sort that wheel hop out  :laugh:
Post by: Rumple on July 30, 2013, 04:39:07 pm
Lol well as im here, what would be the way to go about that?
Post by: Kalpsn2000 on July 30, 2013, 04:45:03 pm
I'm planning on fitting my Twintake this weekend. Hope I don't end up with that noise.
Would be interesting to hear if you manage to sort it.
Post by: Mandy on July 30, 2013, 05:03:30 pm
Not sure if it would make a difference but are the canisters in the right way round?
Post by: Kalpsn2000 on July 30, 2013, 05:29:01 pm
Which is the right way Mandy?
Post by: Rumple on July 31, 2013, 09:22:00 am
Don't think its the KO4 one all seemed to fit perfectly, Couple of videos on YouTube sound very similar to mine but then some not so! I think I got the cones the right way with the cone facing outwards (Engine-Bay > Outside) -- If that makes sense lol still haven't got to the bottom of this!
Post by: Mandy on August 02, 2013, 12:42:31 pm
I'm not sure myself Kalps, I think Robin explains it in his review thread. :happy2:
Post by: josh newman on August 06, 2013, 01:51:04 pm
I just fitted a neuspeed intake at around 3000 rpm its sounds like a screech or a whistle on hard acceleration but if driven with gradual acceleration
it doesn't make the noise I was wondering if it was more to do with the diverter valve but surely it would have made that noise with standard intake if it was the diverter
it is annoying tho
Post by: Rumple on August 06, 2013, 04:58:59 pm
Yea same here, Ive since been told its the noise the K03 makes when spooling? don't know how correct that is but apparently the increase in airflow has this effect on it.
Ive got quite used to the sound now and tbh its not that bad but when I floor it the car sounds like some silly jap toy, I doubt its the DV I only changed mine 3weeks ago to a revision D.
Although when I let off, the pressure release does sound like a dump valve -.-
Post by: josh newman on August 06, 2013, 06:41:26 pm
same mate maybe it is just a common noise it doesn't bother me I was just worried I was losing boost pressure sounded at first as if it was dumping from the turbo lol
I think im going to upgrade to a revision d
