All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Llew on August 05, 2013, 07:33:22 am
Title: Abs bleeding
Post by: Llew on August 05, 2013, 07:33:22 am
I read somewhere not sure but I think it was on Ross tech website that to bleed the abs via vcds all 4 wheels need to be off the ground .  Can anyone confirm this ?
Title: Re: Re: Abs bleeding
Post by: RetroRaz on August 05, 2013, 08:11:03 am
I changed my pump and alex at aks bled my brakes without vcds. He did the one man method.
Sent From My Samsung S3
Title: Re: Abs bleeding
Post by: Scottymon on August 05, 2013, 12:25:15 pm
Bleeding brakes and the ABS cycle are two different things.  The latter you use VCDS to guide you through the process when someone is sat in the drivers seat fighting the ABS pump, it's a good little workout....n.b make sure you have a FULL battery or expect the potential of an empty one once it's completed.
As for all 4 wheels being off ground, I'm not 100% sure, although we did ours with the fronts end up then the rears up... A LOT of black crap came out.
IIRC it's part of the brake bleed service at VW, but most probably don't do it... ask them and watch if possible. :happy2:
Post by: Llew on August 05, 2013, 03:10:07 pm
Thanks  chaps i just wanted to know if its necessary, I just checked Ross tech website this is what it says
There are certain test conditions that must be met before doing this procedure:
Vehicle must on a lift or safe jack stands with no wheels touching the ground
Ignition should be in the "On" position
I guess I,ll wait and get it up on ramps
Post by: skard on August 05, 2013, 03:30:32 pm
When I did mine it was on a ramp but that was by coincidence, I guess it is mentioned as a safety backup suggestion?
