All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Janner_Sy on August 24, 2009, 01:43:06 pm
anybody know of a how to on changing the cam follower. i have the new follower already so may as well change it when i do the fuel pump
If it doesnt come out when you take the pump out. Just put your little finger into the hole the pump fits into and pull it out.
Very very easy to do an once you have the pump off it will take literally 5 seconds to swap
Carl :happy2:
Carl :happy2:
Make sure you bleed the excess fuel from the pump via the Schrader valve before you start and dismantling!
which valve is the schrader valve?
and as Stu pointed out if you haven't disconnected the battery, don't open the drivers door as this primes the fuel system and you'll get wet :wink:
Its on the fuel pump body should have a dust cap on it, it operates like tyre inflation valve, press the needle in the middle to release pressure, better put a rag or similar around it when doing it though :happy2:
and as Stu pointed out if you haven't disconnected the battery, don't open the drivers door as this primes the fual system and you'll get wet :wink:
now thats good to know, lol.bet ten bucks i do that by accident, lol
Its on the fuel pump body should have a dust cap on it, it operates like tyre inflation valve, press the needle in the middle to release pressur, better put a rag or similar around it when doing it though :happy2:
yep seen it, just had a look. thankyou very much :happy2:
Just disconnect the Battery Sy
You wont get wet then :smiley:
Carl :happy2:
i prob will TBH, nothing will need to be re-coded will it though
You might get the steering wheel warning lamp on the dash, you're not using REVO code so that should be ok.
