All Things Mk5 => Mk5 General Area => Topic started by: Matthew. on August 10, 2013, 09:19:24 am
Hi guys,
My cambelt is overdue so will be booking it in shortly. Now coming from Renaultsport cars, I'm not really clued up on the Golf's cambelt details.
What is involved, is it just a cambelt/tensioners/waterpump that needs changing or is there an aux belt, or anything else that needs doing at the same time?
Any advice would be more than welcome :happy2:
no need to change aux belt.
cambelt and tensioners come in a kit, doing waterpump saves on labour charges and the risk of it seizing and destroying the belt & engine, worth doing if you intend to keep the car.
vw dealer price £445 with water pump, but you should to be able to negotiate to £400.
Ah brilliant thanks for that! So it comes as part of a "kit" then.
Thanks a lot for that info!
David at SERE Motors in Belfast did me a cambelt kit for £128. He has dealt with a few members on here - genuine parts too
Mathew, a word of warning if you are doing it yourself, although I have never changed one myself, I know my limits :scared:, a main citroen dealer messed my diesel up, pump was 5 teeth out. There is a vw alignment tool they didn't use so they bodged it. Take it to someone you trust & has done loads of golfs, failing that a vw dealer.
Oh I won't be doing it myself, it will be going to main dealer of trusted indie.
I just wanted to know what is involved :smiley:
