All Things Mk5 => Mk5 General Area => Topic started by: robern2 on August 24, 2009, 05:46:51 pm
Title: DS2500 pads and Whiteline anti-lift kit
Post by: robern2 on August 24, 2009, 05:46:51 pm
Hi,
Does anyone have the part no. for the DS2500 pads for a 2008 edition 30 (front and rear), I can only find front pads listed, some sites suggest wear indicators are not supplied so this has to be bypassed, presumably by VAGCOM ?
Euro performance are coming back to me tomorrow with a price for the fronts.
Also to save me routing around for ages, does anyone know of a DA2500 retailer that also sells Whiteline Anti-lift kits, I was hoping to get away with one set of postage :-)
Title: Re: DS2500 pads and Whiteline anti-lift kit
Post by: wax on August 25, 2009, 04:03:25 am
i bought my ds2500's from venom motorsports, they came with wear indicators. i had same problem r.e rears, so bought ebc's.
Post by: Janner_Sy on August 25, 2009, 06:27:14 am
Hi,
JKM performance http://jkm.org.uk/. they dont list the anti lift kit on their site but if you phone them they have the kit and DS2500 pads
Post by: robern2 on August 25, 2009, 07:50:17 am
thanks, have sent JKM an email.
Anyone know what the issue is with the rear pads, I;d prefer not to mix and match.
Post by: RedRobin on August 25, 2009, 08:03:26 am
I don't know if the brake pad wear sensors can be VAGCOM'd to accommodate DS2500's (vrStu will know), but it's easy and more reliable to visually check them.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRedRobin_05%2FMods%2FFerodo_DS2500.jpg&hash=5c0eaded8b3b0c09e1d631b087cf55cdb577c58f)
Post by: bacillus on August 25, 2009, 08:27:23 am
Yes you can switch it off in VCDS or do a ghetto fix by shorting the terminals.   :smiley:
Post by: RedRobin on August 25, 2009, 08:44:12 am
....Hi bacillus :smiley: - "switch it OFF" you say - Mine has never been switched off (unless AP Racing did so, which I didn't see them do) and no pad sensor has displayed itself to me.
?? :confused:
Post by: DanGB on August 25, 2009, 02:48:01 pm
?? :confused:
same here
Post by: bacillus on August 25, 2009, 03:27:33 pm
If your pads didn't come with the sensor wire then I suspect that they simply shorted the cable that attaches to the pad wear sensor wire. All this does is make a closed circuit like what occurs when using a good pad, fooling the car into believing the pad is ok hence no warning light.
Post by: robern2 on August 25, 2009, 05:34:07 pm
I've also been recommended Tarox Rallye+ pads as an alternative, anyone used them ?
