All Things Mk5 => Mk5 General Area => Topic started by: ginge 0116 on August 30, 2013, 06:52:00 pm
As title really just wondering where my gti should be idleing when up to temp. Thanks sam
On the drive, red traffic lights etc... :happy2:
I think it's around 850 RPM. A shade over 1k when cold.
Before my new Q version TB anywhere between 0.75k and 2.5k :signLOL:
It should be under 1k when warm as above, and over when warming up... iirc, you can change it in VCDS/VAS
Mine's around 750-800 rpm.
about 1k till warm then 800, depends if air con etc on.
Thats ok then thought mine seemed low but it sit around 700 ish and 900 ish when ac on. Cheers all..
Mines a 1.9 tdi, but around 800 or so, doesn't take long for it to drop down, when I start it cold it's at 1k but only for 30 seconds at the most
heres a vid of mine idleing with the ac off ( i think its off, the vid is from a bit back) cars also not up to full temp either.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi176.photobucket.com%2Falbums%2Fw199%2Fv2brett%2Fth_SDC10622.jpg&hash=bc09d6de36391b87999c07f0b44927c44ccbfd1a) (http://i176.photobucket.com/albums/w199/v2brett/SDC10622.mp4)
