All Things Mk5 => Performance Modifications => Modifications & Technical Area => Revo Zone => Topic started by: chedone on September 05, 2013, 11:08:18 am
Hi just wondered if there is a stage 3 file update
mine was installed September 2012
still got a flat spot around 5200 rpm
cheers
simon
No update that I know of!
Any logs showing this flat spot?
Would fitting a RS4 valve not solve this?
If the cause of the flat spot isn't fuel rail pressure related then fitting a rs4 valve is unlikely to help the issue.
just go a reply from revo there is a version 2 out now
also rs4 didnt help
i did fit actuator which helped abit but still there
i will get the update in it this week and post results
