All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: sanj on September 07, 2013, 06:02:54 pm
I've just installed this on my Edition30 which has a MK6 MFSW fitted and was wanting to know how to get the left/right button's when scanning radio station's to work,I have a VCDS cable,all other button's work as they should do.
the left and right buttons will only work if BAP is ticked in the RNS
If you have a Highline don't do it as you won't have NAV and AUDIO menus any more
Thank's for the reply Eddie,i've since found out that it's the right side up/down button's on the steering wheel that control the radio station's so it doe's work after all! :smiley:
You can get all the buttons to work, but you must fit BAP clocks (from late Scirocco or similar) :smiley:
