		All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Jamminjim on September 08, 2013, 12:22:51 pm
				If any Jetta owners out there can help me. Had my car for about a year now and mabey ten out of a thousand times my boot has completly opened when I've held down the boot release button on my keys.....so the question is are my struts just knackered or was I just lucky these few times?!
 Would like to find out an upgraded strut Mabey to replace mine so this ain't just a luck thing  :party:
				We also have a jetta and it does the same ...it opens more often on hot days from remote ...I also found it was slow opening at the top and I used to push it to fully opened till I heard a pop and I'd snapped s end off one gas strut ..I bought a genuine one from tps £30 and popped it on ..boot opens more on remote now so if I'd changed both I recon it would pop on remote every time just couldn't justify buying two lol
 sent using my own fingers
				Seems like it was ment to open this then....not sure I can justify sixty quid on two new struts tho (i won't force them either by the sounds of it!)
 Might try a bit of lubrication and see how that goes!
 Cheers for the reply  :smiley:
				No problem ..looks good when it does pop open ..try making sure the seal isn't sticking to boot either
				Just seen this guys.
 This is worth knowing coz mine just opens a jar and I have to lift it open, not even in hot weather.
 Everyone I know with a Passat get this full on boot opening with the key.
				If I open it then close it then press remote it flys open even faster
				so do we need struts from a passat?
				I just fitted a new jetta one ..wish I had fitted two
