All Things Mk5 => Mk5 General Area => Topic started by: gazbutS3 on August 31, 2009, 05:31:12 pm
evenin all,
could somebody confirm if there should be an O-ring on the connection at the MAF end of the engine cover/intake were the 2 spring clips are please, had the cover off today to fit the catch can and noticed that there was no 0-ring, pretty sure there was one on my GTI and ED30, can't remember if there was one on the S3 and its got knocked off at sometime. Thanx :happy2:
There is one on mine, I remember seeing it on the pipe when I moved it in the garage earlier today :smiley:
I'm sure there should be one on there otherwise it could suck air in after the MAF has already done its business, don't suppose you could have a quick look for the part number could you :smiley:
whats worrying is where has it gone, I took the turbo inlet pipe off to make sure it hadn't fallen in there :laugh:. The engine cover was designed by satan as a tool of torture :grin: Good excuse to get a full intake system :happy2:
Just checking now :happy2:
Ok, I can see it listed as a separate part :confused:
Just to check I thing you mean the o-ring you can see here
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FIMG_2726.jpg&hash=be4bd6994467825872b9428593bb910eb505f6c5)
I checked the part number of this intake pipe
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FIMG_2727.jpg&hash=9e005fbcbf71d7242dbcb29c35915abe651bd414)
And there is no o-ring listed just the pipe itself: -
[pdf]http://www.mk5golfgti.co.uk/forum/downloads/gazparts.pdf[/pdf]
Defo one on mine.
cheers steve, thats a pain in the @rse, will ring the stealer tomorrow, don't fancy havin to buy the whole pipe though :scared:
evenin all,
how did the catch can fitting go ? any tips or pics ? cheers :happy2:
its a pretty straight forward job, no pics sorry. My std PCV had developed a slight leak so changing it can only be good. I fitted the catch can in front of the battery as there is less room on the S3, but it will need relocating if I fit an intake :happy2:
I've got a brand new pipe in the garage Gaz if it helps.
I've ordered 1 now thanx Stu, you can't get the o-ring on its own, so its going to cost 20 odd quid just for an o-ring :smiley:, would like to know where the original 1 went though :scared:
