All Things Mk5 => Mk5 General Area => Topic started by: TornadoRik on September 15, 2013, 08:20:54 pm
Title: Rusting front wing help
Post by: TornadoRik on September 15, 2013, 08:20:54 pm
Hey Guys
Can you help me decide what to do about fixing my rusting front wings please?
- Both my front wings have rust perforating from the inside around the front wheel arches
- I've made a warrantee claim with VW who will only pay for half the cost of replacing the front wings out of good will(£406 payable by me) and that doesn't include any blending. To have them blended will be another 300 putting me about £700 out of pocket.
1) Would blending make a difference (I paid £6k for her so don't really want to pay out 700 quid...)
2) Is £406 quid good for Painted and fitted VW wings?
I've had a look on ebay and it seems i can pick up a pair of front wings painted for about 280, but i'm not sure if they will fit as well as OEM parts or look as good. My car is an 05 plate and i can't see the difference between exposed paint so not sure how much it will have really faded?
The company that gave me the quote via VW was SL Restoration in Crawley who look great (forecourt full of GT3 Porches etc), but I think even with the discount they might be overpriced.
I basically don't want to get ripped off or end up making a bad panel choice and having two front wings that stand out as obviously having been replaced.
Any pointers or guidance is much appreciated.
Cheers, Rik
Title: Re: Rusting front wing help
Post by: zayd on September 17, 2013, 01:07:15 pm
This is a known common fault with the MK5 Golfs and is documented by VW themselves in a PDF, which can be obtained from some members on here.  You are covered under the 12 year anti corrosion warranty and should not have to pay a penny for this work.  Don't accept their crap, you are not liable for any costs mate.  That's why I hate dealers!!!
Post by: Scottymon on September 17, 2013, 01:16:11 pm
Is it really covered under the corrosion guarantee?  I thought VW wriggled out of that, putting it down to a design fault. :rolleye:
Usually the split was 50% VW UK and 50% Dealer, a good will... but I think either the dealers or VW UK aren't awarding these anymore, and ppl are "most recently" at least, being told 0% or 50% max... at 50% it's still very expensive, something in the region of £350+VAT per wing... which when you consider you can get a brand new wing painted to code on your doorstep for less than £140, it's probably worth DIYing.
I've got 1 very bad wing, other starting with signs on both sills and around the rear badge (which has also corroded, like the wheel caps and the f*cking wheels too).
I wish someone would take them to court over it... as yes it is a design flaw, but it's still their design and it has corroded, so should come under the corrosion warranty; it's not like it's a consumer fault and we've been running them on the dakar rally FFS.
Post by: aarondsg on September 17, 2013, 03:09:50 pm
get a after market insurance approved wing from 40-80 each and a good body shop to fit it you will never tell the difference
certain colours can get away without blending what colour is your car ?
Post by: zayd on September 17, 2013, 04:30:47 pm
Can someone just confirm that with the replacement wing arch liners, do they have any different fixings.
I've only bought my car a few days ago and I'm trying to ascertain whether the arches and liners have been replaced.  The arch liner has a screw fixing it to the wing right in the centre.
Post by: aarondsg on September 18, 2013, 01:02:23 am
Most of the time they are the exact same with same location and fixings
Post by: candyman on September 18, 2013, 08:32:17 am
VW will pay for 100% of the repair/paint work as it is all covered the 12 year anti corrosion rubbish. I had both my wings replaced last year with a poor paint match and after much falling out the VW paint shop ended up painting the bonnet and bumper, because VW cannot match paint let alone blend into side doors.
Any paint job outside of the factory will be sub standard.....you just take the risk and inspect well in all light conditions and from all angles.
Don't pay any money.....It's all down to VW
Post by: Scottymon on September 18, 2013, 05:51:22 pm
This is interesting.. so it's just mearly a factor of keeping on at them until they pay?  Read A LOT of threads of peeps being told they won't cover it under the corrosion warranty.
Post by: winrya on September 18, 2013, 05:56:45 pm
VW changed the policy in June this year, they now only cover 50% of cost so you're looking at £450ish for 2 wings and another £300 if you want them blending correctly
Post by: Scottymon on September 18, 2013, 06:02:53 pm
 :rolleye:
Post by: edd666999 on September 18, 2013, 07:30:05 pm
Contact Vw uk and complain. Robert.hazelwood@volkswagen.co.uk is Vw uk director.
They searched local dealers for me and looked into car history, one of the dealers said they would do it for free because they can still make money off Vw with their 50%.
Post by: xjay1337 on September 18, 2013, 08:15:36 pm
I don't know where some of the information is coming from here however I recently went through the process with Ridgeway VW - You can read about it on my build thread on uk-mkivs - uk-mkivs.net/forums/t/520487/3642237.aspx
Basically long story short I would have had to pay £380 for the replacement and painting of 2 front wings.
This INCLUDES BLENDING ONTO THE DOORS - Not the bonnet
If your bodyshop does not do that then you should report that to VW.
Buy 2 genuine wings from TPS and have all the work done at a good local bodyshop. Probably cost you £500 all in and rather give that money to someone decent than VW.
VW really are a shambles with this, what Candyman says is true HOWEVER try actually getting them to do it. Unless you bought the car from VW and it had a full VW service history expect the 50%.
I had to barter by paying £460+ to get the bonnet and bumper resprayed for them to replace the wings for free.
The finish in the paint itself was good aside from one small paint run.
The attitude of the staff however was dreadful.
Post by: Scottymon on September 18, 2013, 08:37:14 pm
Body protection warranty
All current Volkswagen vehicles are fully protected during manufacture against through corrosion for 12 years from the date of first registration.
The only preconditions are:
    The defect must be reported to a member of the Volkswagen Authorised Network as soon as it is discovered and within the warranty period.
    The perforation must not have been caused originally by damage, neglect, insufficient care or maintenance or by external rusting.
    A member of the Volkswagen Authorised Network must be advised about any rusting as soon as it is found.
    All body repairs will be carried out promptly in accordance with the manufacturer's specification and procedures, using only approved parts and materials, so the original level of anti-corrosion protection is maintained.
Post by: xjay1337 on September 18, 2013, 08:44:30 pm
I'd like to think everyone knows that.
After all it is in the handbook.
However like I said try getting the VW dealership to honour it.
Post by: sootpig on September 18, 2013, 09:01:15 pm
Ive had both wings done at my own expense. I  cut the arch liners to avoid any contact with the inner wing and also ripped out the foam sponge which doesn't seem to do anything except act as a sponge :signLOL:
Post by: Scottymon on September 18, 2013, 09:07:46 pm
Oh yeah, everyone knows each and every page from their handbook. :rolleye:
It's not just poor service from VW, this is part of their conditions of sale which they are blatantly swinging around on and sticking two fingers up at the consumer.
I can stomach replacing worn out parts but rust, ffs, come on this is 2013 not 1973.
The arch problem has been around since the Mk3 - It's not just the arches either is it; Sills, Boot, Boot badge, Wheel badges, Wheels...  Sigh, why is this a premium brand again?  Oh yeah, the price.
Post by: Brad Gill on September 19, 2013, 11:31:13 pm
Hi guys i work in a car bodyshop and we get Mk5 golfs in all the time. The reason for the wings rusting is VW think its a good idea to stick Foam inside of the wings. WATER then gets trapped inside the wings and rusts the wings inside out. The repair procedure is to get 2 new wings remove rusty ones Paint and clear inside and out of the new wings. Fit back onto the car WITHOUT the foam they will never rust again. I do jobs on the side and My prices are fairly cheap compair to a bodyshop. Im fully qualified and for members of this forum would replace + PAINT NEW wings and fit for £200 total
Post by: TornadoRik on September 23, 2013, 07:46:19 pm
Thanks for all your replies folks, appreciate your input.
Brad, your site and offer looks great but I think you're up in Scotland and I'm down in Brighton, so the economics on a vPower unleaded return trip don't stack up unfortunately. Interesting on the sponge, sounds crazy!
A friend of mine suggested I do some breakers searches and see if I can find some other Red wings which seemed like a good suggestion - especially if I can find some that are a similar age, but not rusting...!
I have gone via the official route to date and am meeting resistance from VW.
Still at least my Revo Stage one and new Michelin PS3s are making me smile ;0)
Post by: skard on September 23, 2013, 08:07:29 pm
I just removed the sponge from my car the other day, which was still present after a new wing fitted after a claim.
Post by: xjay1337 on September 23, 2013, 11:39:24 pm
Some bodyshops trim the "sponge". So it's not in contact with the lip anymore.
