		All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: ALEXGT382 on September 23, 2013, 08:45:19 pm
				hi guys mk5 gti wiper problems, they dont work from the stalk, but some one has wired a rocker swith down by the fuse box that turns them on. wash works on the stalk, tryed a new stalk and fuses what sends the signal to the wiper unit/ cheers
				Have you tried a new relay?
				Be a relay or wiring if you tried a known good stalk and a working fuse (if indeed you did replace the right fuse.. it's under the bonnet in that fusebox)
Also wipers not going to work if the bonnet is open (or car thinks the bonnet is open)
				as above quotes
"wipers not going to work if the bonnet is open (or car thinks the bonnet is open)"
But will show in the MFD - relay favourite.
				hi cheers for replys, yeah ive checked the bonnet switch and its fine, wheres the relay, and what sends the signal 2 the motor module as i belve it has a permant live cheers
				My approach would be to scan the car first to see what VCDS shows up  - then do few testes with VCDS  - since the cars been tampered with!
				I'd probably do the same as above ^^
				SORTED! wondered why this was doing my f*cking head in, all the strange readings i was getting, got another motor and ound the 1 in there was completly different had 207 writen in black pen on it so f*uck knows wasnt for this car. is ther a turbo change guide about.. many thanks people
				Glad it was fixed.
A turbo charger guide?
Follow the APR pdf guide for the big turbo upgrade.
