All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: AnSGTI on October 02, 2013, 12:35:27 am
Apologies if this is something that's been asked before but I have searched and can't find an answer.....
I've bought an RCD510 with DAB, but obviously I need a DAB aerial/antenna. What have other people done? Can I just buy any DAB aerial and the socket will fit the back of the RCD510?
Thanks! :happy2:
http://www.dabonwheels.co.uk/ Ive installed an internal windscreen item Happy with the reception
Plenty of extra tunes
Thanks, there's quite a choice do you know which one you went for? I think I need to make sure it has fakra connector I think?
I was looking at this on the site you provided:
Kenwood DAB A1 internal glass mount DAB car aerial
I went with this one
http://www.dabonwheels.co.uk/High_Performance_Internal_Glass_Mount_DAB_car_Aerial.html
as they rated it as their best windscreen one they tested. Fitted it to RCD510 DAB as well. It's my first venture into DAB so don't know how good/bad it is really. My mate recons he gets better signal coverage from a factory fitted roof ariel, so you could look into that, but it'll cost over £100ish...
Eddie-NL does a line in roof aerials (Sharkfin) solves the DAB (complete other connections options Nav,GPS etc)
Do the job once and get the best performance out of the Headunit!
So I fitted my RCD 510 with DAB and I bought this antenna:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_907129_langId_-1_categoryId_265868
It has an SMB (female) connector but the RCD has a Fakra type connector. Can I get an adapter or should I get another antenna?
Thanks,
Get a dirt cheap one from eBay
