All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: cb81gti on October 06, 2013, 02:55:11 pm
So, after having my old system turning itself on whenever it felt like it, i found out the radios motherboard was to blame.
I've now been given a RCD310 from a mk6.
Would anyone know if this would be a direct plug and play? or would it need setting up via vagcom?
And what i've read on here, cars prior a certain age (2007??), my car being a 2004 gti, would it need this canbus to stop battery drain?
If the latter, what does it look like, coz i've not a clue!!
on a 2004 car you will need a new gateway
I have new pre-coded gateways
sorry to sound thick, but what is a gateway? and what does it do?
This should help explain it
http://www.my-gti.com/2296/can-bus-gateway-removing-installing-and-upgrading-volkswagen-golf
You'll need one if you fit your replacement, if you don't want a battery issue - best bet is to use Eddie-NL above, as his price is rarely beaten and it will come coded!
