All Things Mk5 => Mk5 General Area => Topic started by: al200 on October 07, 2013, 06:08:10 pm
I am in the process of upgrading my headunit to a rcd510 and found out that I have to upgrade the canbus gateway due to issues with battery drain.
Im looking to get one from ebay for about £40 but can't tell if they are the right revision as the model numbers vary completly. I know I need revision L or above but how do I know its the right one from the model number. The ones I have found have the following codes:
7N0907530R
1K0907530F
Will either of these solve the battery drain issue?
Thanks for any advice.
Anyone shed any light on this?
The one starting 1K0 is where you need L or later.
The 7N0 part is a later model so all of them are ok.
Thank you! :happy2:
