All Things Mk5 => Mk5 General Area => Topic started by: Scottymon on October 16, 2013, 04:51:19 pm
Been a problem for a while this one, used to be fine.
Whilst in gear, any gear, there's about 2-3cm of sideways movement, engaging gears is fine.
I've tried resetting the gearlinkages, even replaced a worn bush, but it didn't make any difference. Is there anything else I could try... is it perhaps a localized gear stick problem?
Anyone else got this?
This may help
http://vimeo.com/26288914
By the way the cable has those bushes on both ends of the cable not just the gear box end!
Thanks mate, yeah, not sure the DD's will make any difference, but thanks for the link. :happy2:
Any further recommendations?
Im in the same boat
If the rear bushes (cables to lever)don't fix it then it could be the gear knob fixing as shown in here or the gear lever bottom bush which is cheap and easy replacement.
http://www.myturbodiesel.com/1000q/a4/shifter-boot-replacement-leather.htm
