All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: darrenchambers on November 18, 2013, 10:56:48 am
Title: DAB aerial 6R0035501D cable route ?
Post by: darrenchambers on November 18, 2013, 10:56:48 am
Hi All,
Based upon the answers kindly provided in this thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,75613.0.html
I have decided to fit the DAB aerial 6R0035501D into my Golf Mk5, I understand that I need to run x2 Fakra extension cables and my questions are these:
1/ Which route should the cables take - floor and up the C pillar or A pillar and along the roofline ?
2/ Since power is delivered to the aerial via the Fakra connectors for DAB, do I need a special extension cable ?
Thanks for all your help people - I promise to give something back soon when I finally fit all this gear.
Regards,
Darren
Title: Re: DAB aerial 6R0035501D cable route ?
Post by: doylebros on November 18, 2013, 07:17:21 pm
Read this it will answer all you want to know!
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
If I was you I would contact Eddie-NL he'll do you a good price on "any cables required" - I would fit the camera cables while your on the fit the camera later - both the aerial and camera are excellent mods!
Post by: darrenchambers on November 18, 2013, 08:02:58 pm
Cheers - that is a great write up & there is a v.good explanation on how to route cables to the back of the car and up the C pillar.
Does the stock aerial cable route along the floor of the car then, or does it run in the headlining?
