All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: diazbtn on November 19, 2013, 06:39:53 pm
Title: Anyone fit cruise to Pirelli GTI Sussex/Surey Area??
Post by: diazbtn on November 19, 2013, 06:39:53 pm
Hi,
Really would like cruise in my Pirelli, no MFSW though but anyone know someone in Sussex / Surrey area?? I have VCDS to code in, not sure how difficult it is especially with the Airbag....... :happy2:
Title: Re: Anyone fit cruise to Pirelli GTI Sussex/Surey Area??
Post by: doylebros on November 19, 2013, 06:51:09 pm
Have read of this
http://www.mk5golfgti.co.uk/forum/index.php/topic,35449.0.html
The man to contact on this is Eddie-NL he will give you the best advice on what parts you need!
Post by: SRC on November 19, 2013, 07:00:31 pm
More local to you (and recommended by me several times here):
http://www.vgsuk.co.uk/ (http://www.vgsuk.co.uk/)
Post by: xjay1337 on November 19, 2013, 07:01:43 pm
Fit it yourself and bring it to me, or come to a meet (let me know in advance) such as Homegrown, WED or Krispy Kreme @ Kingston and I'll enable it for free.
Post by: dokez on November 19, 2013, 07:03:45 pm
Its is easy to fit mate. I struggled only because i had to fit the wire to the panel under the bonnet. Being a pirelli i guess you will have the wire already built in. So its a case of removing the steering wheel and removing the OEM stalk.
That is it.
Post by: Eddie-NL on November 19, 2013, 07:06:17 pm
The OP has vag com
it is the fitting of the stalk that is required
to the OP
if you need a new cruise stalk, I have them for £50
Post by: xjay1337 on November 19, 2013, 07:18:12 pm
Oh. Doh.
 I read it as "I need VCDS". My bad. Too many tabs  :innocent:
Post by: diazbtn on November 19, 2013, 07:19:37 pm
Thanks fellas for all your suggestions, seeing as I've sprained my wrist and I can't even hold a pen at the mo( should have put that in the post) I'll give VGSUK a bell , thanks again all
I could do with some parking sensors as well :happy2: but then again, retrofit Xenons would be nice, I thought buying the car was expensive...... :rolleye:
Post by: SRC on November 22, 2013, 11:25:34 am
Let us know how you get on.  I must confess I'm tempted, just for the M25's variable speed limits!
Post by: SkyJawa on November 22, 2013, 12:11:22 pm
Its well easy if you don't need the wire, if you do then its more than twice the job lol!!
JKM in Pompey do fitting also.
Post by: diazbtn on November 23, 2013, 04:25:26 pm
Think I might give it a go, will update when done :happy2:
