All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Scuba on November 24, 2013, 09:00:45 am
Hello
i am facing a weird problem i have a 2.0 mk4 i've notice that oil is mixing with gaz we have check the car there is no dtc error or any problems as miss fire or anything car is running properly ,just found the oil exciding the limit and can smell gaz.
did any body face a similair problem?
i was searching and as it seems there is many problems to have gaz in oil (bad injector,bad pump ,piston problem or even bad ECU)
any advise guys?
thanks
If it is a TFSI (that has been put in) then it's likely the HPFP seals have gone. A replacement pump can be found on the forums for around £130 :happy2:
Mk4 isn't TFSI.
Who's Gaz anyway??
Mk4 isn't TFSI.
I know that :signLOL:
no, it'll be a 2.0 8v 115ps.
correct it is a jetta GLS 2.0 8V 115HP not FSI
Hey Guys
i have changed the injectors couple of days ago but it seems it didnt solved the problem.they have advise to change the ECU for testing as it happened that ECU Maybe is giving order to the injector to keep it open but it cant be determined on the scanner or anything else .
anybody have any idea
thanks
