All Things Mk5 => Mk5 General Area => Topic started by: TForrest94 on December 05, 2013, 12:07:44 am
Alright guys
As some of you may be aware Christmas is just around the corner so what else to add to the list but car parts?
The golf is having a problem with heating, if it sits long enough it will get to 90, but as soon as I start driving it will drop which is a load of sh!te!! Drove 60 miles the other day and at the end it barely got above 65
So my question to you, is this a result of the coolant sensor or the thermostat sensor or something else? What ever it is how easy is a diy? Or should it go to a garage?
Tommy
If my old MK4 was anything to go by, this could be either of 3 things. Coolant temp sensor, thermostat or just air in your cooling system. I recently had my cambelt replaced and there was still air in the system. After I bled the air out, I had no more issue with the water temp getting to 90.
Cheer for the reply
I had my cambelt changed recently at a vw specialist so I assume they would have bled any air out whilst in the process?
I'm not getting hot air through the vents either if this helps determine anything, on a frosty morning it takes about 5 to 10 minutes before I can even think about driving
This is worth a read
http://www.mk5golfgti.co.uk/forum/index.php/topic,75531.0.html
