All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Lewis86 on December 09, 2013, 05:36:23 pm
This my just be me being an idiot but I've just installed depo projector lights and a hid kit with cancelers built in, I don't have a single problem with the lights or anything however I'm getting a driving light error but only on one side?!
Confused much!!
Are both headlights actually coming on ?
Had this issue with mine where only one light would come on if i started the car with Auto or leaving home lights activated.
Changed the battery and it solved this.
btw I have a standard 'non resistor' set of HID bulbs in my Depo's and just changed a few settings in VagCom and has been fine for the last year.
Eyup fella cheers for the reply but no all the lights are working fine mate I'm confused to high heaven
Must be a faulty canceller. May be worth seeing if someone local with Vag Com can code out the warning then you can do away with the cancellers.
I did think this, which is abit of a shame seen as there brand new! Again cheers fella
