All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: gjseb16 on December 12, 2013, 10:47:20 pm
As above guys any ideas radio reception is rubbish now fitted new Kenwood any ideas
You likely need a powered amplifier, they are under a tenner on ebay. Forgot the part number but if you search on ebay you'll see some variants.
You either need
http://www.roadradio.com/wiring-fascia-adaptors/PC5-136/5973/
http://www.roadradio.com/wiring-fascia-adaptors/CT27AA25/5975/
depending on whether your existing aerial connection is a single or twin fakra. Connect the blue with to a 12v+ power source and the aerial amplifier will have power and you'll get a decent signal.
Keen to know if either of these work?
There was two options. A plug on back of stereo has two inputs looks like it didn't match harness but there is one plug from original harness that goes into it so get the reception hope this helps I'll try get a pick of mine
Tried both adaptors above no improvement at all could do with pick mate if you can
