All Things Mk5 => Mk5 General Area => Topic started by: paulw123 on December 16, 2013, 05:48:29 pm
Title: OEM headunits - do you switch yours off or not
Post by: paulw123 on December 16, 2013, 05:48:29 pm
I've noticed with my RCD510 that when key is turned to 1st position the splash screen starts up, then  when  I start the car, it kind of has a power cut & starts all over again.
Will this do it any harm?, presumably there's a hard drive in there & I don't want to keep crashing it?
Do you manually turn yours on & off?
Title: Re: OEM headunits - do you switch yours off or not
Post by: john87 on December 16, 2013, 06:42:21 pm
When you start the car, the ignition cuts power to the headunit to ensure maximum current is available for the starter motor.. but don't worry about the RCD510, or any of the other OEM headunits for that matter; I have the RCD in my mk6 (from the factory) and it does the same thing  :happy2:
p.s. it's only the RNS510 that has a hard drive
cheers John
Post by: Llew on December 16, 2013, 07:55:33 pm
I never manually turn mines off -as above its nothing to worry about
