All Things Mk5 => Performance Modifications => Modifications & Technical Area => APR Zone => Topic started by: 18Edition30 on December 16, 2013, 09:45:49 pm
Title: Been on the rollers!!
Post by: 18Edition30 on December 16, 2013, 09:45:49 pm
What u guys think? The operator is a revo dealer and he said it was a great map on the car. The only thing he picked up on was the torque was a little conservative, maybe because it hasn't been mapped to the TBE yet as only just been put on?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fb539%2F18Edition30%2Fbdb5a943-ba54-42e0-ac8d-91e46f88247e_zps2044dd6d.jpg&hash=b5e361293ae3d9b27161ea5d55c88e39101855b2)
Title: Re: Been on the rollers!!
Post by: 18Edition30 on December 17, 2013, 08:31:43 pm
Anyone?
Post by: arthur on December 17, 2013, 11:53:51 pm
I don't really know what I'm looking for on any of these readouts, I don't understand them too well!!  but I've just had stage 1 APR and it is great. I haven't put it on a RR though!!
Post by: Horatio on December 18, 2013, 12:01:47 am
Looks good  :happy2:
Your hair clips have fallen out!  :signLOL:
Post by: 18Edition30 on December 18, 2013, 10:14:05 pm
Knew I put them somewhere!!
Post by: Evan@APR on January 07, 2014, 06:17:18 pm
Looks good! Enjoy :happy2:
Post by: 18Edition30 on January 07, 2014, 07:34:50 pm
I enjoy it all the time!
Looking to get stage 2 mapping soon. The only thing I don't have is the pump, which I'm not looking to do.
So will have to see if that ties the mods together nicely!  :happy2:
Post by: 18Edition30 on January 18, 2014, 12:37:24 pm
Speaking with APR and the reason the torque isn't over 300lb/ft is because the HPFP isn't upgraded.
The standard HPFP isn't the same as the S3 and the golf R, its slightly different apparently.
I've now got hardware for stage 2 including TBE and Intake, so looking for the map to be updated now. Just want the missing torque off all the other tuners cars!
Anyone been in same situation? Will it get me that little bit extra torque without the pump? I want the torque around the same as the bhp
Cheers guys.
Will
Post by: MC71 on January 18, 2014, 12:58:45 pm
You should get similar torque to bhp numbers. My R-Tech stage 2 Eddy has 331bhp & 337ft lb with TBE and CAI but without a bigger cooler or upgraded HPFP. What figures do APR suggest you'll get from stage 2?
Post by: Scottymon on January 18, 2014, 01:23:59 pm
Perhaps I'm reading it wrong, but the graph would suggest you're making 110bhp at 3k and about 200bhp at 4k from a K04.   :confused:  Peak power is fine, but under the curve seems a bit weak.
Here's a measily K03 map from APR:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.goapr.co.uk%2Fincludes%2Fimg%2Fproducts%2Fdyno%2F20tfsi_trans_stage1_93_engine.gif&hash=5e1428f073a362e5de1953ea1f85002c4cb8578d)
Post by: 18Edition30 on January 18, 2014, 06:51:05 pm
Exactly what I thought. Couldn't work out why mine are so far apart??
The operator said the dasteks read low on torque, but surely not that much?
When I first contacted APR they suggested a possible boost leak, would it still reach 307bhp with a leak??
But there stage 2 figures are around 320bhp and similar torque. Around 330-340 with HPFP.
Ican have stage 2 mapping without the pump, but to get the extra torque they are suggesting a pump upgrade.
Seems R tech and Revo can have the torque without, so why can't I?..lol  :wink:
Post by: rich83 on January 18, 2014, 07:03:49 pm
Cheers guys.
Will
pretty much nonsense... most ed30s do over 300lbfts with stock pump
Post by: Hedge on January 18, 2014, 07:15:51 pm
I smell BS.  :signLOL:
Post by: rich83 on January 18, 2014, 07:29:06 pm
Its the same pump as far as I know..
Post by: 18Edition30 on January 18, 2014, 08:58:44 pm
Hopefully someone can confirm if it is the same?
Anyone know if it could be a boost leak? If so how do you tell? Just visual on pipe joints etc etc?
Post by: danishmkvgti on January 18, 2014, 09:02:41 pm
Peak torque also seems to come a bit late, was the RR calibrated correctly to your RPM?
Post by: 18Edition30 on January 18, 2014, 11:25:15 pm
As far as I am aware bud yes. They seemed very knowledgeable guys.
Post by: 18Edition30 on January 19, 2014, 09:43:59 am
My mistake, sorry APR! its the Edition 30 has a smaller Cam lobe then the Golf Rs etc etc, that's why they produce more torque not the pump, there the same. Whoopsy, didn't read the email properly.
Still should be over 300ft/lbs though!
Post by: Scottymon on January 19, 2014, 10:08:39 am
Graph looks out, standard GTI makes more power at 3k which just isn't true...
Other than that I wouldn't be bothered chasing high torque it will only cause you to look at replacing the clutch sooner and traction issues unless a linear map.
Post by: Janner_Sy on January 19, 2014, 08:35:27 pm
Before any witch hunt for lost power/torque it might be worth trying a different dyno.  You get a fairly substantial variation between dynos/operators so it could easily be that dyno or operator being les than accurate
