		All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Gti Jal on September 20, 2009, 05:13:29 pm
				Hi Fella's,
Can anyone with VAG COM help me with fitting cruise around slough?
Thanks,
Rik.
				Not perfectly local but Hedge has VCDS if you're willing to travel.
Failing that look at the list of owners in the VCDS forum.
				Thanks - I'm going to put it in and then see if I can get some help with VAG COM.
				I'm close to M4 J11.
				Hi Dom,
I'll get it installed and if ok with you give you a shout via PM
				Be careful with the steering controller when you remove it.  You'll likely get a steering wheel warning on the dash when you put it back together, just drive a few yards in a straight line and it will clear.
				That's fine -just give us a PM as and when. Stu - got any coding guidance?
				Assuming it's a GTi then it's ECU Long Coding and Steering Controller if it's a TDi then it's ECU login (11463) and Steering Controller.
