All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: irish_ram on December 24, 2013, 11:48:52 am
Hi All,
I am about to try this on my golf today until I get around to purchasing a new CAN to fix battery drain.
Has anyone else tried this and worked?
http://www.mk5golfgti.co.uk/forum/index.php/topic,37977.0.html
It works....
Think the title gives it away really :innocent:
" Tested and proven " :booty:
Thanks Guys,
Bloody Maplin's closed early today as it is Christmas Eve. How inconsiderate of them :wink: so will have to wait until Friday to get the bits :sad1:
But hopefully will work once I have done it as I usually mess things up :confused:
Right hooked it all up today and works however it does take up to a minute before my Head Unit switches off an loses power but at least it is all sorted.
Okay so a bit of an issue.
Came out this morning and car would not start. Was ticking over but would start but unlike my battery drain before. Found it was the 20amp fuse I unplugged from f14 to wire my jumper cable into. Put it back and started fine. Problem is I have checked all other vacant fuse locations and none are switched live.
How do I check where the rest of the switched live locations are and also how do I find out about what the current fuses i. There are for?
Owners manual...
What version is your can??
Not sure what version my CAN is but was suffering battery drain before hence why I am trying this fix.
Ill check my manual and see what it says
So looked in the manual but does not seem to make too much sense.
Anyone know the layout of what fuse locations are for what in a 1.4 TSI 170
