All Things Mk5 => Mk5 General Area => Topic started by: Upperoilcan on January 03, 2014, 08:53:02 am
Title: How much ?
Post by: Upperoilcan on January 03, 2014, 08:53:02 am
What's the going rate to have a Divertor valve fitted ?
Been quoted silly money from VW.
Cheers guys.
Title: Re: How much ?
Post by: GTI-Ross on January 03, 2014, 08:54:06 am
takes 5 minutes bro, just buy a jack, axle stands and your good to go.
Post by: Upperoilcan on January 03, 2014, 08:56:20 am
Thanks Russ,but i would'nt dream of doing anything on my car as im hopeless at anything car  :signLOL:
Post by: Upperoilcan on January 03, 2014, 09:25:07 am
And while were at it, it's now Revision G isnt it ?
Post by: chowgar on January 03, 2014, 09:47:04 am
I'm not mechanically minded and did mine fine (bit longer than 5 mins tho)... if its KO3 the only had part is getting to it.... :happy2:
Post by: Scottymon on January 03, 2014, 11:55:06 am
If you can remove a wheel / arch liner you can do the DV on K03... if you're able to open a bonnet you can do the DV on K04 :happy2:
If doing K03, wear some gloves if you've driven the car any distance as the Turb gets silly hot.
Post by: GrayMK5GTI on January 03, 2014, 12:03:35 pm
Its not difficult to do, but would be extremely satisfying if you did it yourself  :happy2:
There are how-to guides and videos all voer the internet - a search on youtube turned up lots of videos.
If you really dont feel confident go to your local TRUSTED garage (doesnt have to be VW or even a specialist- its not a hard job to do)
Take this guide:
http://www.deutscheautoparts.com/newsarticle.aspx?NID=18
and they should have it done in 15mins EASY. As for howmuch - your best getting a quote from your garage as rates vary. Not going to be much for a quick 15min job.
R-Tech swapped mine for free whilst doing pre-map checks
Post by: Upperoilcan on January 03, 2014, 04:14:58 pm
Thanks guys for all your help. :happy2:
Post by: TForrest94 on January 04, 2014, 01:46:45 am
I'm useless when it comes to mechanics but got it sorted in no time it's very simple and is satisfying as said
Got massive hands so it was a bit fidly but very simple indeed good luck!
Tommy
Post by: Roadrebel on January 04, 2014, 07:50:15 pm
So you can reach it from the wheelarch can you? Is that easier than from underneath the car? I have a new one to put on mine asap.
Post by: TForrest94 on January 05, 2014, 03:34:38 pm
I did mine without removing the wheel and arch liner it's a bit more fidly but I didnt have the time to go all out, just lock the wheel left and there's enough room to get around it all
Tommy
