All Things Mk5 => How to Guides / Troubleshooting => Topic started by: ConeKiller on January 16, 2014, 08:58:11 am
Title: Side light staying on, even when car is off and lights are off!
Post by: ConeKiller on January 16, 2014, 08:58:11 am
My drivers side front side light bulb is staying on!
All the lights are off, car is turned off and locked and the indicator is not up or down yet my side light stays on!
I have had to take the bulb out but my car is coming up for its MOT.
Anyone have any ideas what might be causing this? I have tried changing the bulbs but it still happens!
Thanks in advance!
Title: Re: Side light staying on, even when car is off and lights are off!
Post by: doylebros on January 16, 2014, 09:11:10 am
Have you changed any bulbs or undertaken any other work were you may have caught a wire on refitting?
If not my next move would be - start by scanning the car with VCDS if all reads ok - would move on to a few output testes.
If none of the above solve it I'm guessing either water Ingres into a module or module has failed like J519
Post by: john87 on January 16, 2014, 09:58:05 am
Are you leaving your indicator stalk on by mistake?  :wink:
Post by: TomA on January 16, 2014, 10:31:13 am
Did this once, spent ages trying to work  out why lights were on, was driving me mad!!!
Post by: ConeKiller on January 17, 2014, 04:06:18 pm
Cheers guys, passed its MOT as at least it was on however its still an issue  :stupid:
Going to see if a replacement headlight does the trick!
