All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: cuprak1 on September 28, 2009, 12:20:42 pm
Title: USP Motorsports Fluidamprs - engine dampers +10 Wheel hp!
Post by: cuprak1 on September 28, 2009, 12:20:42 pm
Came across a site offering an engine damper which apparently will add gains of 3-10whp and 5-13ft/lbs. of torque depending on your current setup.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.uspmotorsports.com%2Fimages%2Fdamp4.JPG&hash=fc0b1f926318a128fb95683910d5e7b06171e7b1)
The USP Motorsports engine damper carries the following benefits:
-Decreased engine vibration. No more flywheels, crank trigger wheels, or timing gears falling off of the crankshaft. This was unavoidable when revving past 8000rpm in the past.
-Decreased "Clutch/Gear Box Chatter" which is caused by lightweight single mass flywheels.
-Reduction in rpm drops when shifting in a competitive environment.
-Gains of 3-10whp and 5-13ft/lbs. of torque depending on your current setup.
-An overall more efficent and relieable engine.
More info here -  http://forums.vwvortex.com/zerothread?id=4525419
Any one care to elaborate or want to give it a go?
Title: Re: USP Motorsports Fluidamprs - engine dampers + 10 Whp?
Post by: cuprak1 on October 06, 2009, 09:30:12 pm
surprised no one is interested in this!
***Decreased engine vibration. No more flywheels, crank trigger wheels, or timing gears falling off of the crankshaft. This was unavoidable when revving past 8000rpm in the past.
***Decreased "Clutch/Gear Box Chatter" which is caused by lightweight single mass flywheels.
***Reduction in rpm drops when shifting in a competitive environment.
***Gains of 3-10whp and 5-13ft/lbs. of torque depending on your current setup.
***An overall more efficient and reliable engine.
Post by: john_o on October 06, 2009, 09:47:13 pm
most of us cant get past the rev limiter to get near this (nor should we on standard internals perhaps?), not really a mk5 issue
we all run dual mass heavyweight OE flywheels...
Its a good mod , but of limited benefit for the outlay thats probably why the limited interest......
Post by: cuprak1 on October 06, 2009, 10:59:17 pm
not mk5 issue? the kit is made for the golf mk5... and was built designed and tested on one ..
maybe they were using a new valve and camshaft kit to up the rev limit etc
Title: Re: USP Motorsports Fluidamprs - engine dampers +10 Wheel hp!
Post by: john_o on October 07, 2009, 07:41:23 am
ah ok cool, my 'not mk5' comment was in ref  to 'No more flywheels, crank trigger wheels, or timing gears falling off of the crankshaft.' which I thought was more mk4 related.
just trying to add input as to why you have limited interested , would be nice to have though...
Post by: cuprak1 on October 07, 2009, 09:22:46 am
every little helps!
and if it adds horsepower then why not :)
seems people just overlook certain mods and think filter remap and exhaust is the be all and end all of car mods !! its a joke
Post by: Janner_Sy on October 07, 2009, 10:21:40 am
An engine damper?  presuming that it is just a engine mount of some sort, or isd it just a lighter pulley.
Post by: vRStu on October 07, 2009, 10:48:25 am
I think it's a replacement pullywheel for the end of the crankshaft to reduce torsional vibration.  We use a similar type of thing at work on the industrial diesels.
http://www.fluidampr.com/HOWITWORKS.htm
Post by: Chezka on November 08, 2009, 05:53:59 am
This is what i am looking for because some of the above mentioned problems i usually encountered.
_________________
Tube Notcher (http://www.mittlerbros.com/)
Post by: jonnyc on November 09, 2009, 09:14:17 pm
There has to be a crank pulley that is balanced to the crank.. Surely VAG managed to do this when they designed the engine?
An unbalanced crank pulley, meaning pulley that is specifically balanced to that crank (generally a light weight pulley) can literally induce so much torsional vibration into the bottom end that it can snap the crank into two pieces..
Post by: Teutonic_Tamer on October 19, 2010, 11:58:01 am
Sorry, but that is utter snake oil.
Your standard GTI/Eddy/S3 engine already has one of these fitted as STANDARD!
EVERY one of their claims is utter bull sh!t. :fighting:
