All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: cuprak1 on September 28, 2009, 08:17:58 pm
at low speeds when breaking and driving forwards i get a loud ish knocking noise from the front of the car..
any ideas where i can check apart from the obvious
Steering rack?
Sounds like the same problem red Robin had, i think it was something knocking on his anti roll bar. :happy2:
i can see how that would make a noise... cool, any more suggestions before i get under it and scratch my head
Bump for day time people ? anyone.?
Does it do it just the once on start up?
Is it from the front left?
If so it's sounds the same as one of current klonking noises being looked at on mine :sad1:
just once and seems to be coming from driver side... could be wrong though
i have just put up with it.. the car is still doing this
Sorry not to chip in earlier - I've just seen this thread.
My clunking sound was very difficult to find the cause of but VWR eventually discovered it was a failed front wishbone bush - You'd probably have to drop the wishbone to see the problem.
It wasn't anti-roll bar related as some people thought and helpfully suggested.
HTH
My Cupra has the clunk when changing the direction the car last braked. If I move forward and apply the brakes, then reverse (like you do when parking) I hear a clunk. I figure the anti rattle springs may be the cause, however like cuprak1, I have put up with it until I can get it looked at.
yeah Pum sounds like same issue as mine, i think red robin might of hit the nail on head. ill get the powerflex bushes and see what happens
If this info helps, my clunking only happened when the suspension got loaded on that side but sound travels and can fool you about its exact source.
ive got the same thing that happens its like a ping noise when braking reasonabl hard,has anyone fixed his problem??? im not too sure what it is that needs replacing,any help......cheers
