All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Alex156 on February 13, 2014, 10:34:57 pm
Hi,
Going to replace my cam follower at the weekend and want to know if I should use an engine assembly oil/lube or is it sufficient to just use some engine oil? If I do need engine assembly oil/lube can anyone recommend a readily available high quality brand?
With thanks,
Hi, replaced mine not long ago never used any assembly oil just engine oil never had any problems still does not mean I am right though.
I just used oil too. As soon as you start the car it'll be bathed in oil anyway.
I think most just coat with oil.
APR on the other hand state this when installing their hpfp:
If you are using a new cam follower, be sure to use some moly grease on the camshaft side of the follower for initial break in.
Lubricate the O-ring on the outside body of the APR FSI pump with engine oil.
I think they come already oiled from VW
Got some oil off the dipstick when I changed mine.
