All Things Mk5 => Mk5 General Area => Topic started by: J400uk on February 15, 2014, 08:05:32 pm
So I did a quick scan on my newly purchased GTI and a few old fault codes are coming up. Car drives perfectly with no warning lights illuminated and it had quite a lot of work done last month, including a new PCV. Based on that would it be safe to assume these codes don't mean anything serious? Hoping it just means the module hasn't been cleared properly rather than actual problems that need attention! See below...
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 J HW: 1K0 907 115 F
Component: 2.0l R4/4V TFSI 0020
Revision: --H14--- Serial number: VWZ7Z0E2961366
Coding: 040300031C070060
Shop #: WSC 00094 210 71533
VCID: 2D51CF49B4F69704C2D3ED
5 Faults Found:
004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 -- 001 -- - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 152347 km
Time Indication: 0
Date: 2000.00.00
Time: 22:07:39
Freeze Frame:
RPM: 1313 /min
Load: 39.2 %
Speed: 0.0 km/h
Temperature: 18.0°C
Temperature: 8.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.605 V
004244 - Bank 2; Fuel Measuring System 2
P1094 -- 008 -- Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 152347 km
Time Indication: 0
Date: 2000.00.00
Time: 23:28:05
Freeze Frame:
RPM: 1500 /min
Load: 12.5 %
Speed: 20.0 km/h
Temperature: 36.0°C
Temperature: 12.0°C
Voltage: 14.351 V
008597 - Oxygen (Lambda) Sensor B1 S1
P2195 -- 008 -- Signal too Low (Lean) - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 152351 km
Time Indication: 0
Date: 2000.00.00
Time: 00:06:48
Freeze Frame:
RPM: 762 /min
Load: 27.4 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 15.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
012559 - Unknown Error Code
P310F -- 002 -- - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 153822 km
Time Indication: 0
Date: 2000.00.00
Time: 14:25:24
Freeze Frame:
RPM: 619 /min
Load: 33.3 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 34.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.589 V
000679 - Unknown Error Code
P02A7 -- 002 --
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 154306 km
Time Indication: 0
Date: 2000.00.00
Time: 15:34:18
Freeze Frame:
RPM: 4519 /min
Load: 90.2 %
Speed: 88.0 km/h
Temperature: 87.0°C
Temperature: 32.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.843 V
Readiness: 0000 0000
If the car runs ok with no warning dashboard lights illuminated, I would clear the codes and rescan after 10-20 miles.
Perhaps the divertor valve? Early ones Prone to splitting
I'm thinking the repair was probably carried out but the original faults weren't cleared.
Good news everyone, scanned it again today after a week and all the codes have gone! Seems it was fine, probably as above just never got cleared when the PCV etc was done :drinking:
