All Things Mk5 => Mk5 General Area => Topic started by: Scottymon on February 26, 2014, 03:20:04 pm
Bosch £25 delivered: http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2006/p/car-parts/brakes/brake-friction/brake-pad/?101441177&1&c340230c2c6ea4fefdff3edd3b00b41e4a945aca&000036
Pagid £25 delivered: http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2006/p/car-parts/brakes/brake-friction/brake-pad/?101441178&1&12ef27f9cbc97631e090f9d0297e744e16a9078e&000036
ATE £30 delivered: http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_2.0_2006/p/car-parts/brakes/brake-friction/brake-pad/?101441175&1&381b339f1640c6e945a87fec88f06fe100e927bf&000036
vote bitches
:signLOL:
should've been an MP
Have you considered DS2500 pads.
There's more rear brake bias on the mk5 golf than people realise.
Thats true, but little point spending £100 plus on rear pads on standard fronts.....
You'd be better off on larger rear discs on an OEM pad than a Super Pad which won't get hot on a standard disc.
Factoid: Lots of cup cars run standard pads....only becomes an issue after a few hours apparently
Go ATE its a good compound for the 996TT caliper that, quiet and does ok fast road up to a point
Went ATE, who am I to disagree with the forum brake guru! I've had both the Pagid and Bosch before too, lol
You clearly know more than a lot of people think they know. :happy2:
not sure that's entirely fair unless I missed the bit about his front set up.
Also not doubting Dave's knowledge on the subject which followed.
Hmm, you know I was complimenting and agreeing with you, don't you? :wink:
Edit, and also (in principle) with Dave.
