All Things Mk5 => Mk5 General Area => Topic started by: dav1e on February 28, 2014, 07:11:54 pm
Title: Door Rubber Seals
Post by: dav1e on February 28, 2014, 07:11:54 pm
Hi, my rear passenger door seal the one on the bottom of the door has come unstuck - does anyone know what is best to stick it back down with so that it gives a good seal and doesn't let water in - thanks
Title: Re: Door Rubber Seals
Post by: Richie_101 on February 28, 2014, 09:25:23 pm
I had the same problem about 12 months ago, and I used impact adhesive and I haven't had any problems with leaks or it coming unstuck.
This is the stuff, you should be able to pick a tube up for well under a fiver.  :happy2:
(https://www.macbuildingproducts.com/images/01EVOIMP.gif)
Rich.
Post by: dav1e on March 01, 2014, 07:28:21 pm
thanks for that Rich Ill try some
Post by: Zseth on March 01, 2014, 09:53:27 pm
I just did this to a mates car the other day, just used superglue gel
Worked a treat, impact adhesive should be fine as suggested, poor design by vw for seals to be just stuck o
