All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: Markyed30 on March 04, 2014, 07:04:04 pm
Title: autotech internals
Post by: Markyed30 on March 04, 2014, 07:04:04 pm
Anyone fitted them on there own and should I be worried  :driver:
Title: Re: autotech internals
Post by: chris s on March 04, 2014, 07:32:40 pm
I've got this fitted and about 18mths on no issues experienced. I'm
Sure people will say bad things but so long as it's installed properly you should be fine
Post by: Markyed30 on March 04, 2014, 07:47:18 pm
Cheers Chris I'm planning on fitting them myself did you fit yours?
Post by: big eck on March 04, 2014, 10:13:36 pm
I have one fitted. Done by my mechanic and the one thing you need to make sure 100% of is keeping it super clean prior to fitting.
Post by: Markyed30 on March 06, 2014, 04:51:48 pm
Delivered and fitted today working fine just need the map which is this satarday, never had a long 18mm socket so my old man got one from halfords and took it back when done for a refund  :P
This is the guide I followed which is much better than instructions supplied
http://forums.vwvortex.com/showthread.php?5803771-Autotech-HPFP-Upgrade-full-DIY-guide-with-pics
Post by: chris s on March 06, 2014, 06:11:12 pm
What he says and I got a mechanic to do mine
Post by: Markyed30 on March 06, 2014, 08:36:22 pm
Will I need or benefit from an rs4 valve at apr stage 1+??
Post by: big eck on March 16, 2014, 02:39:45 pm
I don't think so but its a cheapish part so you'd be as well fitting it first.
Post by: Scooby mic on March 16, 2014, 03:40:41 pm
This also may help
http://www.autotech.com/mm5/instructions/i127100k.pdf
Post by: sambryant on April 13, 2014, 09:39:26 am
I'm also thinking of going down this route.
