All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: AndreWilk on March 12, 2014, 12:25:16 pm
Hi all,
I've just recently bought a 2007 Mk 5 Gti 5 Door DSG in grey and love it!
Only trouble is the temperature guage on the dashboard doesn't really get off 50 on a long run it will move a bit but soon sinks down when you're moving along.
Now I have read that there are several temp sensors and having spoken to the stealers they have said that there is a coolant temp sensor about £40.
Does anyone know which sensor would directly control the guage on the dashboard.
I still get hot and cold air out of the heater.
The other issue is that once warmed up it can be a little jerky at slow speeds, I was wondering if the thermostat might have something to do with scewing up the correct fueling or if this is a different problem.
Many thanks for all you help!
A
