All Things Mk5 => Mk5 General Area => Topic started by: Pikey Motorsports on March 13, 2014, 09:35:52 pm
bit of a strange one
was doing a long drive in the s3 the other day.. and i started to hear a kind of supercharger sort of whine coming from the rear passenger side speaker.. sometimes it increases with rpm aswell :grin:.. doesnt always do it, sometimes its very faint and stops if i turn the headunit off
all audio is stock audi
any ideals? im no good with electrics atall
Not got a shorter aerial have you
Bad earth somewhere ?
If its increasing with the rev range it points towards an earth fault usually within the speaker it self. I would whip it out and see if there is a loose wire, if not swap the 2 rear speakers over and see if it continues on the other side. Would also be wirth checking the connections in the back of the HU, possibility of a loose wire to that speaker.
HTH
I get that noise when the wifes in the car :rolleye:
HTH
Cheers.. ill check the rear of the h/u first.. pain in the ass removing rear doorcards on s3
