All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: NathED30 on March 19, 2014, 08:02:32 pm
Title: RCD510 Upgrade Coding help needed Birmingham/Coventry
Post by: NathED30 on March 19, 2014, 08:02:32 pm
Hi guys!
So i have just bought an edition 30 with crappy RCD300! I have an RCD510 replacement but i have no idea if i need a new canbus gateway, and if i do i have no idea where to get it coded so that i can prevent the battery drain issue!
Is there anyone in the west midlands has a VCDS that can help me out sorting the new stereo pleaseeeee?!  :smiley:
Title: Re: RCD510 Upgrade Coding help needed Birmingham/Coventry
Post by: skard on March 19, 2014, 08:03:54 pm
What year is your car? Roughly 57 plate onwards should have the new generation gateway, but it is not a given.
Post by: NathED30 on March 19, 2014, 08:06:57 pm
mine is an 07 plate and is build no.53 if thats any help?
Post by: skard on March 19, 2014, 08:09:05 pm
Mine is a smidgen older and came with a K version from the old supplier = battery drain, though I swapped it for a Q version.
All you can do is physically remove it and see the label, or as you first intended...by VCDS scan.
If you do need one, Eddie-NL will sort you out way cheaper than the dealer will.
Post by: J400uk on March 19, 2014, 08:11:13 pm
Check the VIN, if the 10th digit is an 8 that indicates its a 2008MY and should have the newer gateway immune from battery drain.
Post by: NathED30 on March 19, 2014, 08:12:40 pm
is it clearly labelled what letter gateway it is as i dont really know what im looking for lol!
i believe it has to be 'L' or newer is this right? and is it a straight swap or do i have to change it then have it coded to my car?
thanks
Post by: skard on March 19, 2014, 08:15:36 pm
Yep L or newer, some K versions are alright, but it depends what software version they have loaded, so you are better forgetting them.
It has a part number on the front, yea, the letter on the end is what you need. A new or used one will need recoded for the options on your car, Eddie can do this if you tell him.
But do a free visual check first.
Post by: NathED30 on March 19, 2014, 08:18:33 pm
one last question!  :signLOL:
Where is the gateway located?
Post by: Eddie-NL on March 19, 2014, 08:21:54 pm
http://www.mk5golfgti.co.uk/forum/index.php/topic,47405.msg589543.html#msg589543
Post by: NathED30 on March 19, 2014, 08:28:39 pm
Pick up car friday so this should keep me busy over the weekend lol thanks guys!
