General => Detailing => Topic started by: slider955i on March 28, 2014, 07:21:49 am
Title: clean car
Post by: slider955i on March 28, 2014, 07:21:49 am
my car needs a good clean and polish whats the best and easiest to remove all the winter grime before i give it a good polish
Title: Re: clean car
Post by: Rhys_Gti on March 28, 2014, 10:07:22 am
I would use a strong traffic film remover first. Something like crudzilla from dodo is good however this will strip previous wax layers if your polishing and then protecting with wax that's no problem tho. Otherwise something like auto finesse citrus power is good and that is wax safe. Supernatural tar and glue remover is also a good citrus based cleaner I have also heard but never used valet pro citrus pre wash is good and often added in a snow foam for a bit of extra kick. Spray on allow them to dwell for a bit then rinse off. The stronger they are just be careful how long you leave them.
Post by: Saintsteve on March 28, 2014, 10:10:56 am
Hot water and fairy liquid 1st. That will remove everything including old polish and waxes.
If your want something durable , then stick with Autoglms range of products.
That's good enough to get you started.  :happy2:
Post by: slider955i on March 28, 2014, 08:06:09 pm
have ordered some crudzilla
