All Things Mk5 => Performance Modifications => Modifications & Technical Area => Revo Zone => Topic started by: SurreyED30 on April 04, 2014, 04:46:53 pm
Afternoon fellow REVO software owners :signLOL:
I'm currently stage 2 and have got a SPS in its way to me for delivery tomorrow.
I am obviously going to see my settings and also create the performance settings and upload to the car via the SPS unit.
I'm just looking to see what others boost timing and fuelling is set at and what they think of the out come, I know my edition has fuelling set to use 99ron V power Nitro+ But I will make slight tweeks to get the ultimate out of my stage 2 set up
Look forward to reading your replies :happy2:
Jake
What sps switch are you getting as there are two types?
SPS plus mate for 2.0tfsi :happy2:
I'm running b7 t5 f9 stage 2 sometimes turn it up to b9 for a bit more agreesive boosting, but I leave the timing and fuel alone.
This needs to be done in collaboration with data logging. Don't just slap someone else's settings on your car, it doesn't work like that. :happy2:
I run 765 but am at 2+ also I probably have different hardware on the car so what Rich says is right.
I need VAGCOM for that right? Car drives nice just wanted to have a play with the settings to see if I can get it a touch better.
How hard is data logging? And what do you have to do, drive with the laptop?
Also with downloading the SPS file from REVO website, do I just download, plug SPS in and drag it over to the SPS on the removable devices in my computer?
As you can see computers aren't my strongest point :signLOL:
My ed30 running stage 2
B9
T5
F4
Does that sound right?
Think mines 957... settings are different car to car
I have a local dealer near me who does my settings, then I popped to AMD after I disconnected my battery and they turned the fuel right down
B9
T5
F4
Are you running an uprated fuel pump? If not fuel 4 is wildly optimistic. For fuel the lower the number the richer it is.
To confirm for sure if your car is making that you would need to log it with VCDS.
B9
T5
F4
Nope standard fuel pump!
stage 2.
boost 8
timing 5
fuel 9
stage 2.
boost 8
timing 5
fuel 9
I spoke to revo the other day and they said my fuel should be on 8
oh really? mine looks quiet lean compared to others.
im just about to to install my fuel pump and go stage 2+ so see what difference it makes.
yours looks like the right settings, 4 is lean, 9 is rich!
Wrong.... 9 is lean, the lower the number the richer it is.
fight fight fight fight :signLOL:
AMD the sh!t mappers messing around with REVO settings :signLOL:
Did you not ask AMD why they put the settings on what they did?
Did they take your car on a run to adjust, i reckon not.
I wouldn't even bring a Shell lego car to them to assemble :grin:
I sent my settings to revo and they said my car is fueling too lean, it needs to be adjusted to 7/8 :/
mines proberly running lean to then. luckerly im about to go to stage 2+ and will be using a different garage.
