All Things Mk5 => Mk5 General Area => Topic started by: magicgilbert on April 05, 2014, 07:08:53 pm
Iv done a search but Carnt find much on this and hope iv put it on the right section.
I'll be doing my DSG oil in the next few weeks and just wondering what oil to put in and the best place to get if from and a decent price because the oil isn't cheap on some sites.
Iv found this stuff but for a l.s.d, would this be no good in the box?
It's Castrol syntrax l.s.d SAE 75w140 synthetic SAFXJ.
Only other stuff I can find is Fuchs or obviously OEM.
Cheers in advance
Danny
IMO you should stick with the original VAG dsg oil. You'll need 6 litres.
Cheers mate, iv ordered the tool from America to do the job and have vcds to get the oil up to temp, just the oil I wasn't sure about, so basically a trip to VW and order 6 litres
You can do Measure-refill VW DSG fluid change procedure instead of the Factory method if doing it yourself.
http://www.myturbodiesel.com/wiki/dsg-fluid-drain-and-replacement-service-vw-and-audi-stronic-oil-flush/
Stick with vag for dsg!
Yep best use the vw stuff, it's expensive either way really
Cheers for the info all :happy2:
Really . . . yankies cutting corners! What if the level prior to draining was incorrect?
