All Things Mk5 => Mk5 General Area => Topic started by: Gates on April 05, 2014, 07:59:05 pm
Title: Cam follower change help please
Post by: Gates on April 05, 2014, 07:59:05 pm
Evening all, we've had the Gti a few weeks now and I've decided to go and get a new cam follower from tps for the fuel pump and change it. The problem is I've looked at the how to guide on here and looked at my fuel pump and mine doesn't have the bleed valve on the bottom right corner. It is the older type with the metal pipes rather than a rubber one.
What I'm wanting to know is how do I release the pressure in the pump before I undo the pipes so I don't get fuel all over the place? And it looks a bit tight to get a socket and m8 spline bit past the metal fuel pipes onto the bottom bolt to take it off.
Any help would be really appreciated.
Gates
Title: Re: Cam follower change help please
Post by: cuprajake on April 05, 2014, 08:03:11 pm
Loads of rags, around the area and around the spanner. There not that bad to do
Post by: Gates on April 05, 2014, 08:13:36 pm
Cool thanks mate, I'll give it a go tomorrow as it's a bit dark now and ill prob mess it up trying to rush in the fading light :)
Post by: bacillus on April 05, 2014, 08:54:44 pm
Just remember not to open the driver's door whilst you have the lines disconnected.
Post by: Gates on April 05, 2014, 09:17:37 pm
I will mate, thanks. Ill be disconnecting the battery just to be sure too. Lol
Post by: Tortaruga on April 05, 2014, 10:21:20 pm
You can pull the fuse and run the engine until cut out. There isn't any real need to do this though.
Post by: Gide76 on April 06, 2014, 07:43:22 pm
I didn't do anything other than put a tea towel underneath the pipes when removing. Only the smallest trickle of fuel and the tea towel caught the banjo bolt!
